Beam Deflection and Stress Equations Calculator for Beam Supported on Both Ends Loaded at any Location
Structural Beam Deflection, Stress, Bending Equations and calculator for Beam Supported on Both Ends Loaded at any Location.
Open
Beam Deflection, Stress Beam Supported on Both Ends Calculator
Beam Stress between load and "a" load point
Beam Stress between load and "b" load point
Beam Stress at load application
If the cross section is constant this is the maximum stress.
Beam Deflection for location between load and "a" point
Beam Deflection for location between load and "b" point
Maximum Beam deflection at load
Let "a" be the length of the shorter segment and "b" of the longer one.
The maximum deflection
is in the longer segment, at |
E = | Modulus of Elasticity | lbs/in2 | (N/mm2) |
W = | Load | lbs | (N) |
s = | Stress at the cross-section being evaluated | lbs/in2 | (N/mm2) |
a = | Some distance as indicated | inches | (mm) |
b = | Some distance as indicated | inches | (mm) |
l = | Some distance as indicated | inches | (mm) |
Z = |
z = |
- Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 404 or,
- Machinery's Handbook, 23st Edition, Page 260 or,
- Machinery's Handbook, 27st Edition, Page 261
- Beam supported One End, Pin Opposite End and two Partial Distributed Load Separated.
- Brittle Failure Theories Computing Safety Factors Excel Spreadsheet Calculator
- Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Two Tapered Distributed Load
- Flexural Strengthening of Reinforced Concrete Beam with FRP Laminates Spreadsheet Calculator
- Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Triangular Distributed Load
- Calculator for a Beam supported One End, Pin Opposite End and Single Moment at End Applied
- Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load at End
- Beam Deflection Equations / Calculator with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Deflection Equations / Calculator with End Overhanging Supports and a Single Load
- Beam Deflection Equations / Calculator Cantilevered Beam with One Load Applied at End
