Beam Bending Equations Calculator Supported on Both Ends Single Load at Center
Beam Deflection and Bending Equations Calculator Supported on Both Ends Single Load at Center.
Open Calculator Supported on Both Ends Single Load at Center
Beam Stress between load and support points
Beam Stress at center of constant cross section
Beam Deflection between load and support points
Maximum Beam deflection at load
W = | Load | lbs | (N) |
s = | Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
Z = |
z = |
- Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
- Deflections apply only to constant cross sections along entire length
- Machinery's Handbook, 21st Edition, Page 404 or,
- Machinery's Handbook, 23st Edition, Page 260 or,
- Machinery's Handbook, 27st Edition, Page 261
- Beam Stress Equations / Calculation - Both Ends Overhanging Supports, Load at any Point Between
- Structural Beam Bending Stress and Deflection Equations / Calculation - Fixed at One End, Supported at the Other, Load at Center
- Beam Stress Deflection Equations / Calculator - Fixed at One End, Supported at the Other, Load at any Point
- Beam Stress Deflection Equations / Calculator - Fixed at Both Ends, Load at Center
- Beam Stress Deflection Equations / Calculator - Fixed at Both Ends, Load at any Location
- Beam Stress Deflection Equations / Calculator with Uniform Loading
- Beam Stress Deflection Equations / Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads
- Beam Stress Deflection Calculator Equations - Continuous Beam, with Two Equal Spans, Uniform Load
- Beam Deflection Calculator Equations with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Deflection Equations with End Overhanging Supports and a Single Load
- Beam Deflection Calculator Equations Cantilevered Beam with One Load Applied at End
