Beam Deflection and Stress Equations Calculator for Beam Supported on Both Ends With Overhanging Supports of equal Length and Uniform Loading
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Supported on Both Ends With Overhanging Supports of equal Length and Uniform Loading .
Open
Deflection and Stress Beam For Supported on Both Ends Calculator
Beam Stress between nearest support point and outer end
Beam Stress between the two supports
Beam Stress at load center
Beam Stress at supports
Stress at supports
If cross-section is constant, the greater of these is the maximum stress.
If l is greater than 2c, the stress is zero at points on both sides of the center.
If Beam cross-section is constant and if l = 2.828c, the stresses at supports and center are equal and opposite, and are:
Beam Deflection between support point and outer end
Deflection between support point and outer endDeflection between support point and outer end
Beam Deflection between supports
Beam Deflection at the ends
Deflection at center
If l is between 2c and 2.449c, there are maximum upward deflections at points
on both sides of the center, which are,
E = Modulus of Elasticity psi
(N/mm2)
W = Beam Load lbs (N)
s =  Beam Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
c = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Beam Deflections apply only to constant cross sections along entire length.
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 26
