Beam Deflection ad Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Single Moment at End Applied
Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Single Moment at End Applied
Beam Deflection Moments Equation
Beam Stress Maximum
W = | Beam Load, Total | lbf | (N) |
w = | Beam Unit Load | lbs/in | (N/mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Beam Shear Load | lbf | (N) |
Mmax = | Beam Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Beam Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Beam Stress Deflection Calculator with Fixed Ends Moment Applied
- Beam Parabolic Deflection Equation Calculator with Variable Shape
- Beam Cubic Parabola Shape Deflection Equation Calculator with Variable Shape Fixed End Single Concentrated Force Applied
- Combined Stress Circular Cantilever Beam in Direct Compression and Bending Equations and Calculator
- Combined Stress Circular Cantilever Beam in Direct Tension and Bending Equations and Calculator
- Combined Rectangular Cantilever Beam in Direct Compression and Bending Equations and Calculator
- Combined Rectangular Cantilever Beam in Direct Tension and Bending Equations and Calculator
- Combined Loading on Circular Beam or Shaft in Direct Compression and Bending Equation and Calculator
- Combined Loading on Circular Beam or Shaft in Direct Tension and Bending Equation and Calculator
- Combined Loading on Rectangular Beam or Shaft in Direct Compression and Bending Equation and Calculator
- Beam Deflection Equations / Calculation Cantilevered Beam with One Load Applied at End
