Beam Deflection Calculator with stress and moment formula fof Fixed Ends Moment Applied
Beam Deflection, Stress, Strain Equations and Calculators
Beam Stress Deflection Equations / Calculator with Fixed Ends Moment Applied
Preview Calculator
Reaction and Shear Equation
Bending Moments Equation
E = Modulus of Elasticity psi
(N/mm2)
W = Load, Total lbf (N)
w = Unit Load lbs/in (N/mm)
y = Deflection inches (mm)
Vmax = Shear Load lbf (N)
Mmax = Moment lbs-in (N-mm)
