Beam Deflection and Stress for Variable Shape Fixed End Single Concentrated Force Applied
Beam Deflection, Stress, Strain Equations and Calculators
Beam Deflection Equation Calculator with Variable Shape Fixed End Single Concentrated Force Applied
- Cross Section: Rectangle width b constant and depth y variable.
- Elevation 1) Top straight line and bottom patabola. 2) Complete parabola.
- Plan: rectangle
Equations
Ss = I / c2
c2 = (5 b) / 8
I2 = (19 b3 d) / 480
y2 = (6 P x) / (b Ss )
h = (6 P l / b Ss)1/2
f = ( 8 P / b E ) ( l / h )3
P = | Force | lbf | (N) |
h = | Deflection | inches | (mm) |
Se= | Section Modulus | ||
a, b, c, d, x, l = | Some distance as indicated | inches | (mm) |
- Civil Engineering Formulas, Tyler G. Hicks, PE International Engineering Associates
- Beam Stress Deflection Equations / Calculator with Fixed Ends Tapering Loading
- Beam Stress Deflection Equations / Calculator with Fixed Ends Moment Applied
- Beam Parabolic Deflection Equation Calculator with Variable Shape
- Beam Cubic Parabola Shape Deflection Equation Calculator with Variable Shape Fixed End Single Concentrated Force Applied
- Combined Stress Circular Cantilever Beam in Direct Compression and Bending Equations and Calculator
- Combined Stress Circular Cantilever Beam in Direct Tension and Bending Equations and Calculator
- Combined Rectangular Cantilever Beam in Direct Compression and Bending Equations and Calculator
- Combined Rectangular Cantilever Beam in Direct Tension and Bending Equations and Calculator
- Combined Loading on Circular Beam or Shaft in Direct Compression and Bending Equation and Calculator
- Combined Loading on Circular Beam or Shaft in Direct Tension and Bending Equation and Calculator
- Combined Loading on Rectangular Beam or Shaft in Direct Compression and Bending Equation and Calculator
- Combined Loading on Rectangular Beam or Shaft in Direct Tension and Bending Equation and Calculator
