Calculator for Circular Cantilever Beam in Direct Compression and Bending Equations
Circular Cantilever Beam in Direct Compression and Bending Equations and Calculator
Rule 1: For every calculated normal stress there is a corresponding induced shear stress; the value of the shear stress is equal to half that of the normal stress.
Rule 2: For every calculated shear stress there is a corresponding induced normal stress; the value of the normal stress is equal to that of the shear stress. The tables of combined stress formulas, below, include equations for calculating both maximum nominal tensile or compressive stresses, and maximum nominal shear stresses.
Maximum Nominal
Shear Stress
d = | Diameter | inches | (mm) |
L = | Length of Beam | inches | (mm) |
Fy = |
Applied Load | lbs | (N) |
Fx = | Applied Load | lbs | (N) |
σ' a = |
Stress, Tensile or Compressive | Lbs/in2 | (N/mm2) |
σ' b = | Stress, Tensile or Compressive | Lbs/in2 | (N/mm2) |
τ'a = | Stress , Max. Nominal Shear | Lbs/in2 | (N/mm2) |
τ'b = | Stress , Max. Nominal Shear | Lbs/in2 | (N/mm2) |
- Machinery's Handbook, 21st Edition, Page 404 or,
- Machinery's Handbook, 23st Edition, Page 260 or,
- Machinery's Handbook, 27st Edition, Page 261
- Beam Bending Equations / Calculation Supported on Both Ends Uniform Loading
- Beam Bending Equations / Calculation Supported on Both Ends Single Load at Center
- Beam Bending Equations / Calculation Supported on Both Ends Loaded at any Location
- Beam Bending Equations / Calculation Free and Guided on One End, Rigid one End With Uniform Load
- Beam Bending Equations / Calculation Supported on Both Ends With Overhanging Supports of equal Length and Equal Loads
- Beam Bending Equations / Calculation Supported on Both Ends Loaded Two equal Loads
- Beam Bending Equations / Calculation with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Bending Equations / Calculation with End Overhanging Supports and a Single Load
- Beam Bending Equations / Calculation Cantilevered Beam with One Load Applied at End
