Beam Deflection and Stress Equations Calculator for Beam with End Overhanging Supports and a Single Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam with End Overhanging Supports and a Single Load.
Open
Deflection, Stress Beam End Overhanging Supports and Single Load Calculator
Beam Stress between load and nearest support
Stress between load and nearest supportĀ
Beam Stress between the two supports
Beam Stress at support nearest load
Beam Deflection between load nearest (adjacent support)
Beam Deflection between supports
Beam Deflection between non-loaded end and nearest support
Beam Deflection at the load
Beam Deflection at the unloaded ends
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
c = Some distance as indicated inches (mm)
w = Some distance as indicated inches (mm)
d = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 407 or,
  • Machinery's Handbook, 23st Edition, Page 263 or,
  • Machinery's Handbook, 27st Edition, Page 264
