Beam Stress and Beam Deflection Formula and Calculator Beam Both Ends Overhanging Supports Symmetrically, Uniform Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam supported Both Ends Overhanging Supports Symmetrically, Uniform Load
Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Beam Stress at any Given Point
Adjacent end stress:
Open: Adjacent End Stress Beam Calculator
Beam Stress Between indicated supports
Open: Between Indicated Supports Beam Calculator
Beam Stress at Critical Locations/Points
Stress at each support:
Open: Stress at Each Support Beam Calculator
Beam Stress at Center of Beam.
Open: Stress at Center of Beam Calculator
Beam Stress at support next to end of length d:
If l is greater than 2c, the stress is zero at points
Beam Stress On both sides of the center
If cross-section is constant and if l = 2.828c, the stresses at supports and center are equal and opposite, and are:
Beam Deflection at any Point
Between supports
Open: Deflection Between Supports Calculator
Beam Deflection Between each support and adjacent end,
Open: Deflection Between each Support and Adjacent End Calculator
Beam Deflection at Ends
Open: Deflection at Ends Calculator
Z = | Section modulus of the cross-section of the beam I/z | in3 | (mm3) |
z = | distance from neutral axis to extreme fiber (edge) | inches | (mm) |
W = | Load | lbs | (N) |
s = | Beam Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
u = | Some distance as indicated | inches | (mm) |
c = | Distance as indicated | inches | (mm) |
L = | Some distance as indicated | inches | (mm) |
l = | Some distance as indicated | inches | (mm) |
- Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 405 or,
- Machinery's Handbook, 23st Edition, Page 261 or,
- Machinery's Handbook, 27st Edition, Page 26
- Stress Deflection Equations and Calculator for a Beam supported One End, One End, Cantilevered at Defined Location and Distributed Load Between Supports
- Stress Deflection Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load Between Supports
- Stress Deflection Equations and Calculator for a Beam Supported One End, Cantilevered at Defined Location and Single Moment Applied at End
- Stress Deflection Equations and Calculator for a Beam Supported One End, Cantilevered at Defined Location and Uniform loading Applied
- Stress Deflection Equations and Calculator Beam Supported Uniform loading Applied on Cantilevered End
- Beam Deflection Equations / Calculator with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Deflection Equations / Calculator with End Overhanging Supports and a Single Load
- Beam Deflection Equations / Calculator Cantilevered Beam with One Load Applied at End
