Beam Deflection and Beam Stress Equations Calculator for Fixed at One End, Supported at the Other, Load at Center
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at One End, Supported at the Other, Load at Center.
Beam Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
Beam Loads and Moment at Reaction points as Defined
Open: Loads at Reaction points as Defined Beam Calculator
General Beam Stress at any Given Point
Beam Stress between point of fixture and load
Open: Stress Between Point of Fixture and Load Beam Calculator
Beam Stress Between support and load
Open: Stress Between Support and Load Beam Calculator
Beam Stress at Critical Locations/Points
Maximum Beam stress at point of fixture
Open: Stress Maximum at Point of Fixture Load Beam Calculator
Beam Stress is zero at x = (3⁄/1l)l
Greatest negative Beam stress at center
Open: Greatest negative stress at center Beam Calculator
Beam Deflection at any Point
Between point of fixture and load
Open: Deflection between point of fixture and load Calculator
Beam Deflection Between support and load
Open: Deflection between support and load Calculator
Critical Beam Deflections
Maximum Beam deflection
v = 0.4474l
or
Open: Maximum Deflection Calculator
Beam Deflection at load
Open: Deflection at load Calculator
W = | Load | lbs | (N) |
s = | Beam Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
u = | Some distance as indicated | inches | (mm) |
a, b, c & d = | Some distance as indicated | inches | (mm) |
L = | Some distance as indicated | inches | (mm) |
l = | Some distance as indicated | inches | (mm) |
Z = |
z = |
- Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 405 or,
- Machinery's Handbook, 23st Edition, Page 261 or,
- Machinery's Handbook, 27st Edition, Page 26
- Beam Stress Beam Deflection Equations / Calculator with Partial Uniform Loading
- Beam Stress Deflection Equations / Calculator with Partial Tapering Loading
- Beam Deflection Stress Beam Deflection Equations / Calculator with Fixed Ends Tapering Loading
- Beam Stress Beam Deflection Equations / Calculator with Fixed Ends Moment Applied
- Beam Parabolic Deflection Equation Calculator with Variable Shape
- Beam Cubic Parabola Shape Deflection Equation Calculator with Variable Shape Fixed End Single Concentrated Force Applied
- Combined Beam Stress Circular Cantilever Beam in Direct Compression and Calculator Equations and Calculator
- Combined Beam Stress Circular Cantilever Beam in Direct Tension and Deflection Equations and Calculator
- Combined Rectangular Cantilever Beam in Direct Compression and Deflection Equations and Calculator
- Combined Rectangular Cantilever Beam in Direct Tension and Deflection Equations and Calculator
- Combined Loading on Circular Beam or Shaft in Direct Compression and Deflection Equation and Calculator
- Beam Deflection Equations / Calculator Cantilevered Beam with One Load Applied at End
