Beam Deflection Calculator and Stress Equations for Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads
Structural Beam Deflection, Stress, Bending Equations and calculator for a Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads.
R1 = Load Left Point
R2 = Load Right Point
R = Load Center
Open: Load at R1, R2, and R Calculator
Beam Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Beam Stress at any Given Point
Open: Stress at any Given Point Calculator
Beam Stress at Critical Locations/Points
Open: Stress at Critical Points Calculator
Beam Deflection at any Point
Open: Deflection at Defined Points Calculator
I = | Area Moment of Inertia | in4 | (mm4) |
W = | Load | lbs | (N) |
s = | Beam Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
u = | Some distance as indicated | inches | (mm) |
a, b = | Some distance as indicated | inches | (mm) |
L = | Some distance as indicated | inches | (mm) |
l = | Some distance as indicated | inches | (mm) |
Z = |
z = |
- Please note letter "l " (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition
- Machinery's Handbook, 23st Edition
- Machinery's Handbook, 27st Edition
- Stress Deflection Strain Equations and Calculator Beam Supported Tapering Load Applied
- Stress Deflection Strain Moment Equations and Calculator Beam Supported Partial Tapering Load Applied
- Stresses in Three Dimensions Excel Spreadsheet Calculator
- Beam Stress & Deflection Equations / Calculator Free and Guided on One End
- Beam Stress & Deflection Equations / Calculator Moment Applied at Defined Location
- Beam Stress Deflection Equations / Calculator with Partial Uniform Loading
- Beam Stress Deflection Equations / Calculator with Partial Tapering Loading
- Beam Stress Deflection Equations / Calculator with Fixed Ends Tapering Loading
- Beam Stress Deflection Equations / Calculator with Fixed Ends Moment Applied
- Beam Parabolic Deflection Equation Calculator with Variable Shape
- Beam Deflection Equations / Calculator with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Deflection Equations / Calculator with End Overhanging Supports and a Single Load
- Beam Deflection Equations / Calculator Cantilevered Beam with One Load Applied at End
