Beam Deflection Formula and Calculator Free and Guided on One End, Rigid one End With Single Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Free and Guided on One End, Rigid one End With Uniform Load.
Open
Beam Stress Deflection Free One End, Rigid one End Single Load Calculator
Beam Stress at Any Point
Beam Stress at the fixed support
Beam Deflection at specified point
Beam Deflection at the free end
W = | Load | lbs | (N) |
s = | Beam Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
l = | Some distance as indicated | inches | (mm) |
Z = |
z = |
- Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 410 or,
- Machinery's Handbook, 23st Edition, Page 265 or,
- Machinery's Handbook, 27st Edition, Page 267
- Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Two Tapered Distributed Load
- Flexural Strengthening of Reinforced Concrete Beam with FRP Laminates Spreadsheet Calculator
- Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Triangular Distributed Load
- Calculator for a Beam Deflection supported One End, Pin Opposite End and Single Moment at End Applied
- Stress Deflection Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load at End
- Beam Deflection Equations / Calculator with End Overhanging Supports and a Single Load
- Beam Deflection Equations / Calculator Cantilevered Beam with One Load Applied at End
