Deflection Calculator for Triangular Shape Fixed End Single Concentrated Force Applied Beam Deflection
Beam Deflection, Stress, Strain Equations and Calculators
Beam Triangular Shape Deflection Equation Calculator with Variable Shape Fixed End Single Concentrated Force Applied
- Cross Section: Rectangle: width y variable, depth h constant
- Elevation: Rectangal
- Plan: Triangle
Equations
Ss = b d2 / 24
I2 = b d3 / 36
y = 6 P x / ( h2 Ss )
b1 = 6 P l / ( h2 Ss )
Deflection at A:
f = ( 6 P / b1 E ) ( l / h )3
P = | Force | lbf | (N) |
f = | Deflection | inches | (mm) |
Ss= | Section Modulus | in3 | (mm3) |
a, b, c, d, x, l = | Some distance as indicated | inches | (mm) |
- Civil Engineering Formulas, Tyler G. Hicks, PE International Engineering Associates
- Beam Bending Equations / Calculation Free and Guided on One End, Rigid one End With Uniform Load
- Beam Bending Equations / Calculation Supported on Both Ends With Overhanging Supports of equal Length and Equal Loads
- Beam Bending Equations / Calculation Supported on Both Ends Loaded Two equal Loads
- Beam Bending Equations / Calculation with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Bending Equations / Calculation with End Overhanging Supports and a Single Load
- Beam Bending Equations / Calculation Cantilevered Beam with One Load Applied at End
- Beam Bending Equations / Calculation Cantilevered Beam with Uniform Load
- Beam Bending Equations / Calculation Supported on One End, Rigid one End With Uniform Load
- Beam Bending Equations / Calculation Cantilevered Beam with Load at Location Between Support and Load
