Circular Plate Deflection Calculator, Moments and Stress Calculation Fixed and Supported Ends
Engineering Calculator for Circular Plate Deflection, Moments and Stress Calculator
References at bottom of page.
Click on formula image below for larger view:
Engineering Calculator for:
References: Roark & Young, Formulas for Stress and Strain, pp 332, 362
- Beam Bending Equations / Calculation Supported on Both Ends Uniform Loading
- Beam Bending Equations / Calculation Supported on Both Ends Single Load at Center
- Beam Bending Equations / Calculation Supported on Both Ends Loaded at any Location
- Beam Bending Equations / Calculation Free and Guided on One End, Rigid one End With Uniform Load
- Beam Bending Equations / Calculation Supported on Both Ends With Overhanging Supports of equal Length and Equal Loads
- Beam Bending Equations / Calculation Supported on Both Ends Loaded Two equal Loads
- Beam Bending Equations / Calculation with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Bending Equations / Calculation with End Overhanging Supports and a Single Load
- Beam Bending Equations / Calculation Cantilevered Beam with One Load Applied at End
