Calculator for Beam Deflection and Stress Equations Calculator for Beam Supported on Both Ends Loaded Two equal Loads
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Supported on Both Ends Loaded Two equal Loads.
Open
Stress and Deflection Beam Supported Both Ends Loaded Two Equal Loads Calculator
Beam Stress between nearest load and support point
Beam Stress between the two loads
Beam Stress at each load application and all points between
Beam Deflection between nearest load and support point
Beam Deflection between loads
Maximum Beam Deflection at Center
Beam Deflection at loads
W = | Load on Beam | lbs | (N) |
s = | Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
y = | Beam Deflection (Positive Upward Beam Deflection, Negative Downward | inches | (mm) |
a = | Some distance as indicated | inches | (mm) |
v = | Some distance as indicated | inches | (mm) |
l = | Some distance as indicated | inches | (mm) |
Z = |
z = |
- Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 405 or,
- Machinery's Handbook, 23st Edition, Page 261 or,
- Machinery's Handbook, 27st Edition, Page 262
- Beam Deflection Equations / Calculator with End Overhanging Supports and a Single Load
- Beam Deflection Equations / Calculator Cantilevered Beam with One Load Applied at End
- Beam Deflection Equations / Calculator Cantilevered Beam with Uniform Load
- Beam Deflection Equations / Calculator Supported on One End, Rigid one End With Uniform Load
- Beam Deflection Equations / Calculator Cantilevered Beam with Load at Location Between Support and Load
- Beam Deflection Equations / Calculator Free and Guided on One End, Rigid one End With Single Load
- Beam Stress & Deflection Equations / Calculation - Both Ends Overhanging and Supported Unsymmetrical with Uniform Load
- Beam Stress Equations / Calculator - Both Ends Overhanging Supports, Load at any Point Between
- Structural Beam Stress Deflection Equations / Calculation - Fixed at One End, Supported at the Other, Load at Center
